Hi Fred,
Autodesk Map has series of commands and routines in both the UI and API that
will let you do this.
There are programs out there like MADTRAN that will help you do this, but
I'm not sure that they will work with the RSO system.
Have a look at Map 5; I think it will save you a lot of work.
Cheers,
David Walsh
"Fred" wrote in message
news:1E37B0A695AC8D1BF0D6FAB4BC5C8B17@in.WebX.maYIadrTaRb...
> I need to convert LatLong coord (WGS84 datum) into RSO. Source dwg were
> digitized using BORNEO RSO. How do I locate a LatLong coord on the dwg?
does
> any one out there have a formula to translate coordinates? 'planning to
> write code it on lisp or vba. I'm not a map expert and I'm only using
> AutoCAD 2000.
> Thanks.
