AutoCAD Map 3D General Discussion
New Member
0 Kudos
Post 1 of 3
Lat and long
206 Views, 2 Replies
08-07-2012 07:09 AM
So i have a set up prepared of 0degrees 0 minutes E TO 12 degrees E then 0 degrees north to 12 degrees north, how do i input coordinates so i can have an exact position od 3degrees 14 minues E 6 degrees 45 minutes N? massively need help here!!
194 Kudos
Post 2 of 3
Re: Lat and long
08-08-2012 10:55 PM in reply to: alexandra.thomson
Whoa, madame, ain't gotcha...
Please write all again, as you should explain it to your grandmother, slooowly and eaaasy.
Valued Mentor
35 Kudos
Post 3 of 3
Re: Lat and long
08-09-2012 02:43 AM in reply to: antoniovinci
try this format after you start the line
@distance<n45d45'45"E
