AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Lat and long
2 REPLIES 2
372 Views, 2 Replies
Lat and long
So i have a set up prepared of 0degrees 0 minutes E TO 12 degrees E then 0 degrees north to 12 degrees north, how do i input coordinates so i can have an exact position od 3degrees 14 minues E 6 degrees 45 minutes N? massively need help here!!
2 REPLIES 2
antoniovinci
Whoa, madame, ain't gotcha...
Please write all again, as you should explain it to your grandmother, slooowly and eaaasy.
parkr4st
in reply to: antoniovinci
try this format after you start the line
@distance<n45d45'45"E
”Boost
