AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
LAS points
6 REPLIES 6
400 Views, 6 Replies
LAS points
Good moorning:
I´m working whit a LAS points draw an i want cut only a little of space in my draw.
i have 500 points in this format and only i need 100.
Somebody can tell me how can i do that? I want delete some LAS points of my draw
Thank you very much for your colaboration
6 REPLIES 6
antoniovinci
Sir, a .LAS file contains millions of points, not only 0.5k...
thank you very much but i knew the LAS files have a millions of points, the 0.5K points was only example.
Do you know how can i select and cut only a freatured area?
antoniovinci
Well, I guess you can't crop a .LAS file in Autodesk environment, while it's possible with opensource software.
A clever workaround would be the following:
  1. download a trial version of Autocad Civil3D
  2. import and index your point cloud
  3. create a surface based on it
  4. add a "cutting" boundary to that surface.
    You'll get no cropped .LAS file, but better than nothing, sir.
rmacan
in reply to: antoniovinci
I was just working on a Lidar file earlier today in MAP 2012 and noticed that there was a command to do a Spatial Filter when indexing the file.  Unfortunately, it's another function of MAP that doesn't work very well.  I kept getting error messages and gave up on trying to do a location filter.
TerryDotson
If you were to consider third party software, MapWorks Surfaces contains a Mass Points Processor that will let you select multiple LAS files and a bounding object or rectangle.  If a LAS file hits outside the boundary it's ignored completely (for speed).
I tried your sistems and i got my objetive whit Global Mapper whit autocad map 3D was imposible.
Thank you very much to everybody for help me
”Boost
