The lines have data that I would like to display on the drawing like material, diameter, construction year, etc. How do I make them display?
Do I need to use Annotation Template? If so, could someone walk me through how to set it up? I've tried the help but I'm lost on step 3. It says "A new drawing window opens, called Map Annotation Template Editor.dwg. Define the template in this window and save it before returning to the Define Annotation Template dialog box." I don't get a window that's called that. I get the screen where I normally edit my blocks with the yellow tinted background color. And how do I define the template in here?
Thank you.
