Are you in a new dwg that you attached the dwg to that you imported the sdf
into, or in the dwg that you are trying to query?
There's about a dozen ways to get what you want.
Murph
www.map3d.wordpress.com
"Wesleypjones" wrote in message news:6227329@discussion.autodesk.com...
I am using AutoCAD Civil 3d 2009. I have a bunch of shp files that I have
been using to create drawing via FDO connection.
My problem now comes in the form of a client who wants to have digital dwg
files that they can manipulate themselves after I have created them. They
do not have map 3d or civil 3d. So, I need to import the shp files as
closed polylines instead of connecting to them. This is fine I just create
an sdf of the subset that I want and import that with object data. No
problem.
My problem now lies in the fact that I need to:
a. label features using the object data (there are sometimes hundreds of
features that need to be labelled so doing them individually is not an
option.
and
b. Query using object data in order to change line weight of (in this case)
roads that have a certain classification.
Does anyone know any way of doing these things?
I have tried to create a query in the Map Explorer > Query Library but when
I choose data as the query type and object data in the following dialog
there is no object data table present in the drop down.
Any help would be greatly appreciated.
