AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
label advanced placement not working
2 REPLIES 2
cmbarrett1
377 Views, 2 Replies
Trying to limit labels using advanced placement.  Display shows correctly but, text does not show on plots (hard copy, dwf, pdf, etc)  Any ideas?
Craig Barrett
2 REPLIES 2
tjmapper
in reply to: cmbarrett1
What version of Map are you using?
It is a known issue that will never be fixed in older versions of Map. I have had good luck with it in 2011.
cmbarrett1
Using 2009
I've gathered as much from other posts.  I increased my sheet to D-size from 8x11 and found advanced placement works better but, not 100%.
Well thanks for your reply - guess I'll just use ArcInfo.
”Boost
