AutoCAD Map 3D General Discussion
Active Contributor
ABielecki
Message 1 of 4 (235 Views)
Label above thick line
235 Views, 3 Replies
02-11-2014 06:31 AM
Hi. Do you have any idea how to make in AutoCAD Map 3D 2014 label above wide line?
I can do it when line is thin (attachment 1). But when I need thick as a result I see my label on the line (attachment 2).
I set label to be on the bottom (attachment 3) but it is to low. I susspect that I need to make some statement but I have no idea hao to build correct statement in this situation.
Can anybody help?
GIS
Active Contributor
ABielecki
Message 2 of 4 (158 Views)
Re: Label above thick line
02-13-2014 12:10 AM in reply to: ABielecki
Hey Guys, do you have any idea how to solve my problem.
I think that resolution is connected with some special statement but I don't know which.
GIS
Valued Mentor
parkr4st
Message 3 of 4 (147 Views)
02-13-2014 04:28 AM in reply to: ABielecki
Not the prettiest but you can use either of text ghosting or background color to make the text visible on top of the line
dave
Active Contributor
ABielecki
Message 4 of 4 (126 Views)
02-17-2014 03:54 AM in reply to: parkr4st
Thanks but it's hard to say that this is satisfing solution. Any others ideas?
GIS
