AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Label above thick line
3 REPLIES 3
435 Views, 3 Replies
Hi. Do you have any idea how to make in AutoCAD Map 3D 2014 label above wide line?
I can do it when line is thin (attachment 1). But when I need thick as a result I see my label on the line (attachment 2).
I set label to be on the bottom (attachment 3) but it is to low. I susspect that I need to make some statement but I have no idea hao to build correct statement in this situation.
Can anybody help?
3 REPLIES 3
Hey Guys, do you have any idea how to solve my problem.
I think that resolution is connected with some special statement but I don't know which.
parkr4st
Not the prettiest but you can use either of text ghosting or background color to make the text visible on top of the line
dave
in reply to: parkr4st
Thanks but it's hard to say that this is satisfing solution. Any others ideas?
”Boost
