AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Join atributes from xls to table in shp
2 REPLIES 2
481 Views, 2 Replies
Sorry, if I repeat topic but I can't find any solution here.
Do you know how to join atributes from xls/xlsx to table in shp file?
I attache some sample files.
I have shp with 3 poligones. Each has two atributes in the table. I prepared some table in excel. Now I want to join this file to shp's table.
Do You have any Idea how to do this?
Should I connect this file though FDO? (ODBC)
2 REPLIES 2
antoniovinci
Have the table and the shape a common ID..?
Murph_Map
First create a view in the Excell file.
Next use the Windows ODBC admin to create an odbc connection to that speadsheet/file
Then in Map3D use FDO to make a ODBC connection and select the odbc connection you created in the ODBC Admin.
Then you can create a join to the FDO connected shp file provided you have a command field in both.
Beware the version of Map3D, MS Office, and 63/32 bit os has a lot to it working.
Murph
Supporting the troops daily.
”Boost
