I'm getting the following error. Does anyone know how to remedy this?
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.ArgumentOutOfRangeException: Time-out interval must be less than 2^32-2.
Parameter name: dueTm
at System.Threading.Timer..ctor(TimerCallback callback, Object state, TimeSpan dueTime, TimeSpan period)
at Autodesk.InfoCenter.PaletteMgr.SetCommCenterPollTimer()
at Autodesk.InfoCenter.PaletteMgr.FirstInvoke()
at Autodesk.InfoCenter.PaletteMgr.OnAppIdle(Object sender, EventArgs e)
at System.Windows.Forms.Application.RaiseIdle(EventArgs e)
at ?A0x2b7cf235.OnIdle()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 17.1.0.0
Win32 Version: 17.1.219.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/AcdbMgd.DLL
msvcm80
Assembly Version: 8.0.50727.1433
Win32 Version: 8.00.50727.1433
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2/msvcm80.dll
acmgd
Win32 Version: 17.1.51.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/acmgd.DLL
AcISOMetadataEditor
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/ISO%20Metadata%20Editor/AcISOMetadataEditor.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ResourceManagement
Assembly Version: 11.0.79.0
Win32 Version: 11.0.079.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/ResourceManagement.DLL
Redland.NET
Assembly Version: 1.0.2.1
Win32 Version: 1.0.2.1
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/Redland.NET.DLL
AcInfoCenterConn
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/AcInfoCenterConn.DLL
AdInfoCenter
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/AdInfoCenter.DLL
Autodesk.Interop.AcInetEngine
Assembly Version: 17.1.51.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/Autodesk.Interop.AcInetEngine.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AdInfoCenter.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/en-US/AdInfoCenter.resources.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
zxvc4loa
AcLayer
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/AcLayer.DLL
AcMgdShared
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/AcMgdShared.DLL
acmgdinternal
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/acmgdinternal.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/en-US/AcLayer.resources.DLL
Autodesk.Interop.WSCommCntr1
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/Autodesk.Interop.WSCommCntr1.DLL
Autodesk.Interop.WebServices1
CodeBase: file:///C:/Program%20Files/AutoCAD%20Map%203D%202008/Autodesk.Interop.WebServices1.DLL
System.Web.Services
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
