I am working with shp files from a county mapping office.
I have no trouble bringing in all the shp's I need (over 30) except for two.
When I check the data connect dialog I see the following message "invalid feature schema element name".
see attached screen shot.
Thoughts?
for me the message means that there is a fieldname (column in DBF) that has a dot in the fieldname.
If you have a change to modify the struction then rename that field.
- alfred -
