AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Invalid feature schema element name
1 REPLY 1
rsBria
1598 Views, 1 Reply
I am working with shp files from a county mapping office.
I have no trouble bringing in all the shp's I need (over 30) except for two.
When I check the data connect dialog I see the following message "invalid feature schema element name".
see attached screen shot.
Thoughts?
Tags (2)
1 REPLY 1
Alfred.NESWADBA
in reply to: rsBria
for me the message means that there is a fieldname (column in DBF) that has a dot in the fieldname.
If you have a change to modify the struction then rename that field.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
