AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Intersecting GIS Parcel Data with an alignment ROW
6 REPLIES 6
526 Views, 6 Replies
I am a beginner with AutoCad software, and I am currently using Civil 3D/Map 3D 2009.
I imported a shp. file containing property information (owner, area, address, etc), and also imported an alignment row as a sdf. file. The row is a closed polygon.
My goal is to intersect these two types of data so that I end up with information on the number of properties effected by the row.
Is civil 3d 2009 capable of doing this? If so, how? I found a youtube video on using the 'Offset Alignment' command with Civil 3D 2010, however, is not the same for 2009.
Any help would be appreciated, Thanks.
6 REPLIES 6
Murph_Map
With Map3D you need to use data connect and bring the parcel shp file and ROW sdf file in as FDO features, then use the intersection option on doing a overlay analysis. As for the ROW offset you need to ask in the Civil3D forum.
Murph
Supporting the troops daily.
NateMoore
I like Murph's overlay suggestion - if you save the result as a shapefile, you can open the .dbf in Excel or Open Office and pull any stats or do math there.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
Tags (1)
parkr4st
in reply to: NateMoore
intersection does give 100% right answer.  exceptions are where the ROW crosses multiple sections of one property i.e  L S U Z shaped parcels, rivers & roads with S curves, which create two or more new polygons in the intersect file.  This inflates the number of affected parcels from the original parcel layer.
intersect sdf  file;  data table and select all, copy and paste to excel for data analysis.   is that acceptable for this case?
Dave
parkr4st
in reply to: parkr4st
I meant does not give 100 % right answer. Smiley Mad
dave
NateMoore
It's a bit of a hassle, but you could take the original file and the overlay result, join the two using the feature ID as the key in a one to many join - that will get all the data in one place, but you'll still need to massage it (possibly) in Excel.
Nate Moore, GISP
Global Services
Autodesk, Sarl
parkr4st
roundabout
intersect   source ROW    Overlay Parcel   result is Row_intersect
Theme the Row_intersectSDF using the FeatId2 as individual values. the number of rules = the number of parcels the ROW crosses.
Dave
”Boost
