AutoCAD Map 3D General Discussion
New Member
mdalbello
Message 1 of 7 (254 Views)
Intersecting GIS Parcel Data with an alignment ROW
254 Views, 6 Replies
07-28-2011 06:20 AM
I am a beginner with AutoCad software, and I am currently using Civil 3D/Map 3D 2009.
I imported a shp. file containing property information (owner, area, address, etc), and also imported an alignment row as a sdf. file. The row is a closed polygon.
My goal is to intersect these two types of data so that I end up with information on the number of properties effected by the row.
Is civil 3d 2009 capable of doing this? If so, how? I found a youtube video on using the 'Offset Alignment' command with Civil 3D 2010, however, is not the same for 2009.
Any help would be appreciated, Thanks.
Murph
Message 2 of 7 (239 Views)
Re: Intersecting GIS Parcel Data with an alignment ROW
07-28-2011 03:13 PM in reply to: mdalbello
With Map3D you need to use data connect and bring the parcel shp file and ROW sdf file in as FDO features, then use the intersection option on doing a overlay analysis. As for the ROW offset you need to ask in the Civil3D forum.
Murph
Supportting the troops daily.
Product Support
NateMoore
Message 3 of 7 (227 Views)
07-29-2011 01:24 PM in reply to: mdalbello
I like Murph's overlay suggestion - if you save the result as a shapefile, you can open the .dbf in Excel or Open Office and pull any stats or do math there.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
Valued Mentor
parkr4st
Message 4 of 7 (202 Views)
08-01-2011 03:05 AM in reply to: NateMoore
intersection does give 100% right answer.  exceptions are where the ROW crosses multiple sections of one property i.e  L S U Z shaped parcels, rivers & roads with S curves, which create two or more new polygons in the intersect file.  This inflates the number of affected parcels from the original parcel layer.
intersect sdf  file;  data table and select all, copy and paste to excel for data analysis.   is that acceptable for this case?
Dave
Valued Mentor
parkr4st
Message 5 of 7 (201 Views)
08-01-2011 03:13 AM in reply to: parkr4st
I meant does not give 100 % right answer. :smileymad:
dave
Product Support
NateMoore
Message 6 of 7 (187 Views)
08-02-2011 08:57 AM in reply to: parkr4st
It's a bit of a hassle, but you could take the original file and the overlay result, join the two using the feature ID as the key in a one to many join - that will get all the data in one place, but you'll still need to massage it (possibly) in Excel.
Nate Moore, GISP
Global Services
Autodesk, Sarl
Valued Mentor
parkr4st
Message 7 of 7 (168 Views)
08-03-2011 12:27 PM in reply to: NateMoore
roundabout
intersect   source ROW    Overlay Parcel   result is Row_intersect
Theme the Row_intersectSDF using the FeatId2 as individual values. the number of rules = the number of parcels the ROW crosses.
Dave
