AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Insert dwg issues
4 REPLIES 4
386 Views, 4 Replies
Insert dwg issues
I am trying to insert a dwg on top of another one but it's not putting it in the right place. They both have the same coordinate system, both unitless, and both tie to each other. If I open both in Global Mapper, they both lay on top of each other but that is not the case in autocad.
I also tried to reference the dwgs and that did not help either. Anybody knows how can I insert both dwgs and have them lay on top of each other?
4 REPLIES 4
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
A few quick ideas :
Please open each DWG and check :
- UNITS / UI - I imagine they have to be the same !? (Meters or Feet or No Units)
- BASE - Must be Zero,Zero
If necessary correct then ReSave and ReTest ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
in reply to: braudpat
Got it. Thanks
ryanmcauley
i have this issue also with autocad map, after the last version update.  The units are the same along with base.  just certain shapes/dxfs are not able to come into the correct location
ryanmcauley
did not work for me
”Boost
