AutoCAD Map 3D General Discussion
Active Member
0 Kudos
Post 1 of 11
Insert dialog box
742 Views, 10 Replies
09-07-2011 08:53 AM
How do I bring up a dialog box with the insert command? after I type 'insert' it asks me in the command line what the name of the block is. I would like to bring up the dialog box so that I can browse to my block library etc.
Set FILEDIA=1
Sounds like you have a bad install and/or the wrong dotnet frame work installed.
196 Kudos
Post 2 of 11
Re: Insert dialog box
09-07-2011 12:14 PM in reply to: estbe
Set FILEDIA=1
Active Member
0 Kudos
Post 3 of 11
09-09-2011 07:57 AM in reply to: antoniovinci
the filedia is already set to 1. any other ideas
Active Contributor
3 Kudos
Post 4 of 11
09-09-2011 08:15 AM in reply to: estbe
Set CMDDIA to 1
Mark Martinez
DC CADD
Mark Martinez
Enceptia
Active Member
0 Kudos
Post 5 of 11
09-09-2011 08:23 AM in reply to: MarkMartinez
Yes, I tried that already. Does the AcFields support file have anything to do with the dialog boxes. My autocad session was having trouble finding certain support files.
Active Contributor
3 Kudos
Post 6 of 11
09-09-2011 08:27 AM in reply to: estbe
If that's the case, a Repair/Reinstall from Control Panel is in order to get the files required on your system.
Mark Martinez
DC CADD
Mark Martinez
Enceptia
Active Member
0 Kudos
Post 7 of 11
09-09-2011 08:29 AM in reply to: MarkMartinez
how do you do that
10 Kudos
Post 8 of 11
09-11-2011 03:58 PM in reply to: estbe
Go to:
START > Control Panel > Programs and Features > Right click  on your Autodesk Program and select "Unistall/Change". It will guide you thru the Repair process.
Autodesk AutoCAD Map 3D 2015
Windows 7 Professional
Service Pack 1
Intel(R) Core(TM) i5-4430 CPU @ 3.00 GHz
8.00 GB RAM
Active Member
0 Kudos
Post 9 of 11
09-20-2011 06:03 AM in reply to: grimline
Are there any other settings that control use of dialog boxes. Other commands: Hatch, Layer manager, Dimstyle also do not come up as a dialog box which I would like them to. My system administrator would like to avoid doing a repair, reinstall.
207 Kudos
Post 10 of 11
09-20-2011 04:27 PM in reply to: estbe
Murph
Supportting the troops daily.
