AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Insert dialog box
10 REPLIES 10
Message 1 of 11
estbe
1159 Views, 10 Replies
Insert dialog box
How do I bring up a dialog box with the insert command? after I type 'insert' it asks me in the command line what the name of the block is. I would like to bring up the dialog box so that I can browse to my block library etc.
10 REPLIES 10
Message 2 of 11
antoniovinci
in reply to: estbe
Set FILEDIA=1
Message 3 of 11
estbe
in reply to: antoniovinci
the filedia is already set to 1. any other ideas
Message 4 of 11
mmartinez7
in reply to: estbe
Set CMDDIA to 1
Mark Martinez
DC CADD
Mark Martinez
ASTI
Message 5 of 11
estbe
in reply to: mmartinez7
Yes, I tried that already. Does the AcFields support file have anything to do with the dialog boxes. My autocad session was having trouble finding certain support files.
Message 6 of 11
mmartinez7
in reply to: estbe
If that's the case, a Repair/Reinstall from Control Panel is in order to get the files required on your system.
Mark Martinez
DC CADD
Mark Martinez
ASTI
Message 7 of 11
estbe
how do you do that
Message 8 of 11
in reply to: estbe
Go to:
START > Control Panel > Programs and Features > Right click  on your Autodesk Program and select "Unistall/Change". It will guide you thru the Repair process.
Message 9 of 11
estbe
Are there any other settings that control use of dialog boxes. Other commands: Hatch, Layer manager, Dimstyle also do not come up as a dialog box which I would like them to. My system administrator would like to avoid doing a repair, reinstall.
Message 10 of 11
Murph_Map
in reply to: estbe
Sounds like you have a bad install and/or the wrong dotnet frame work installed.
Murph
Supporting the troops daily.
Message 11 of 11
in reply to: Murph_Map
what is the correct version of dotnet for cad 2012?  we have .net 4.
”Boost
