Hi all, I am fairly familiar with most aspects of map 3d. But these three things i one cant get my head around and two can't seem to get them to work.
There is not much help online, although i think my main problem is i cannot login to anything. They say your Username is "Administrator" and the password is blank. This does not work. I think we would find the storm & sanitary analysis very useful but its greyed out under the wastewater tab.
I'm very lost I dont even know what the first two do, and i could figure out how to use the storm and sanitary analysis if i could get it to work, but i think you need the first two to access it. Also any commands like _tbgenerategraphic or _TBConnectivity (for example) come back as unknown commands.
Any help would be appreciated
While I"m not currently using 2012, the Map3D 2010/2011 rourtines for object classification required loggin in with user name "superuser" and password "SUPERUSER" (case sensitive).
Perhaps these would work for the newer product?
Hi
Storm & Sanitary Analysis (SSA):
Otherwise the SSA button is disabled.
Administrator user:
Can you give me a bit more context on this one? Where do you want to log-in with that user? Did you already create a industry model system user on the database (e.g. MAPSYS) with the Industry Model Setup application? etc.
Best regards
Tobias
@thepworth wrote:While I"m not currently using 2012, the Map3D 2010/2011 rourtines for object classification required loggin in with user name "superuser" and password "SUPERUSER" (case sensitive).
Two different animals there Todd.
Thanks for replying Tobias,
Where I'm trying to log in is (From the ribbon, in the Maintenance workspace) Home > Open Project. I really want to try out the Storm & Sanitary Analysis.
Cheers
Exploring a bit more, i've learnt that you need oracle for it all to work, yes? Actually google reckons you can maybe get around that somehow. Does oracle ship with autocad or would you need to pay a shed load of money for it? (If thats the case i wonder how many people ended up using the idustry analysis enterprise blah blah.
Thanks again
Thanks again
There is an Express Edition for free noncommerical use. I haven't used it in a while but beware you best know a few things about databases and setting it all up. I ran it on a laptop and if you're not carefull it can make your pc crawl.
to the best of my knowledge, the free editions of MySQL and Oracle DB's have a 4GB size limit. Is this correct?
@thepworth wrote:to the best of my knowledge, the free editions of MySQL and Oracle DB's have a 4GB size limit. Is this correct?
Used to be yes so I would think it still is. But's that more then E$RI Personnel Geodatabases is and more than MS Acess.
Worked good enough for me to demo Map3D and FDO with them.
Hi guys, several questions here. Last time I fiddled with SSA it was the stand-alone 2011 version but I need to get going with the newer versions. I'm currently running Map 3D 2012 and about to upgrade to 2014 very soon. I can find all kinds of documentation about SSA's features and functions, how to use guides, etc, but nothing about actually finding and installing it.
@weibelt wrote:Storm & Sanitary Analysis (SSA):
- You need to select SSA in the installer
- You need to open a wastewater industry model in Map 3D.
Would that have been done in the network install or the local install?
Where do I even find the SSA button? (I can't find a Stormwater tab anywhere, not even the custom settings. Totally new to this Industry Model stuff.)
Is SSA still incorporated in Map 3D 2014? Do I need to tell our IT guys anything special to make sure it gets set up right when they do the upgrade? (They do our network install for 2 seat licenses, then we do our own local install.)
Anybody? I found the Wastewater panel that has the SSA button greyed out (in the Maintenance workspace, wonder why the big wide internet didn't mention that) and I tried to reinstall Map 3D 2012 to make sure it included SSA. But I couldn't find an SSA option anywhere in the install menus. It would be a humongous help to my projects. Can anybody please tell me step by step how to find it in the installation?
Edit: OK so after searching the internet all week, it does appear that this has to be done at the network install level as per this article. It would appear that is why the option didn't show up when I tried a local reinstall. Is that right?
It won't let me edit the previous post to fix the link so here is the right one: http://upandready.typepad.com/up_and_ready/2012/10/civil-3d-2013-where-is-storm-sanitary-analysis-su....
