AutoCAD Map 3D General Discussion
*Dupuis, Lorraine
Message 1 of 3 (243 Views)
Importing UTM coordinates
243 Views, 2 Replies
11-19-2002 11:37 PM
Can anyone suggest a reasonably priced software that can import survey
points and plot blocks with attributes....I have tried Pointor and it seems
to work relatively well. I am just wondering if there is anything elso out
there?
BillGates
Message 2 of 3 (243 Views)
Re: Importing UTM coordinates
11-20-2002 07:04 AM in reply to: *Dupuis, Lorraine
If you are simply seeking the data from each block, Excellink may work for you. I am of course assuming you are not using Autocad Map which would do it for you.
*Ivan
Message 3 of 3 (243 Views)
Map 6 and Oracle 9i (client configuration)
11-21-2002 03:18 AM in reply to: *Dupuis, Lorraine
Hi everyone,
I installed Oracle 9i (release 1), oracle client 9i, and acadmap 6, too. But
acadmap 6 doesn't work the oracle command, do you know if there any idea
about the configuration of the oracle client to connect fine?
I appreciate the answering,
Ivan
