AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Importing UTM coordinates
2 REPLIES 2
830 Views, 2 Replies
Can anyone suggest a reasonably priced software that can import survey
points and plot blocks with attributes....I have tried Pointor and it seems
to work relatively well. I am just wondering if there is anything elso out
there?
2 REPLIES 2
BillGates
If you are simply seeking the data from each block, Excellink may work for you. I am of course assuming you are not using Autocad Map which would do it for you.
Hi everyone,
I installed Oracle 9i (release 1), oracle client 9i, and acadmap 6, too. But
acadmap 6 doesn't work the oracle command, do you know if there any idea
about the configuration of the oracle client to connect fine?
I appreciate the answering,
Ivan
”Boost
