AutoCAD Map 3D Forum
Welcome to Autodeskā€™s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Importing text, blocks and attributes are too big
4 REPLIES 4
d.kerkhoff
2157 Views, 4 Replies
I'll try to import a text file with a string: pointnumber, easting, northing, elevation, discription, but I get very big blocks and attributes in my drawing. I use Autocad 2011 Map 3D, on a windows XP OS. I'll importing the text string with the import command. Easting and Northing are for the position. The Elevation, pointnumber and discription are attributes from a block. I can only choose a block: "Map_Survey_point" This is the only block I can choose. When I import the text, the scale from the importing blocks are too big. How can I change the size of the block and attributes? Anybode an idea?
4 REPLIES 4
Murph_Map
in reply to: d.kerkhoff
You can use Quick Select "qselect" after you import the points then change the  scale in the property palette. I have no idea why the default is so large or why they scale up.
Murph
Supporting the troops daily.
d.kerkhoff
in reply to: Murph_Map
Murph.
Thanks for your help. That is the solution. It works! Thank you very much.
Duncan
Murph_Map
@d.kerkhoff wrote:
Murph.
Duncan
You are welcome. šŸ™‚
Murph
farad51
Hi mr kerkhoff,
I am new to autocad map....can you please show me how you imported text in your map ...I am having great difficulty i doing this.thanks
ā€Boost
