AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Importing text, blocks and attributes are too big
4 REPLIES 4
2165 Views, 4 Replies
I'll try to import a text file with a string: pointnumber, easting, northing, elevation, discription, but I get very big blocks and attributes in my drawing. I use Autocad 2011 Map 3D, on a windows XP OS. I'll importing the text string with the import command. Easting and Northing are for the position. The Elevation, pointnumber and discription are attributes from a block. I can only choose a block: "Map_Survey_point" This is the only block I can choose. When I import the text, the scale from the importing blocks are too big. How can I change the size of the block and attributes? Anybode an idea?
4 REPLIES 4
Murph_Map
You can use Quick Select "qselect" after you import the points then change the  scale in the property palette. I have no idea why the default is so large or why they scale up.
Murph
Supporting the troops daily.
in reply to: Murph_Map
Murph.
Thanks for your help. That is the solution. It works! Thank you very much.
Duncan
Murph_Map
@Anonymous wrote:
Murph.
Duncan
You are welcome. 🙂
Murph
Hi mr kerkhoff,
I am new to autocad map....can you please show me how you imported text in your map ...I am having great difficulty i doing this.thanks
”Boost
