AutoCAD Map 3D General Discussion
Member
paduroiul
Message 1 of 8 (906 Views)
Importing survey points with numbers in AutoCAd 2011 Map
906 Views, 7 Replies
05-03-2012 02:38 AM
How can I import survey points in AutoCAD Map. The points are stuctured like this (point number, easting, northing, altitude)
e.g.
52499.990.537499.983.388399.872
antoniovinci
Message 2 of 8 (898 Views)
Re: Importing survey points with numbers in AutoCAd 2011 Map
05-03-2012 06:02 AM in reply to: paduroiul
Command: _AECCCREATEPOINTS then choose PENZ as point type (it works for me in Map2006, I hope in your 2011 too...)
Murph
Message 3 of 8 (878 Views)
05-03-2012 03:31 PM in reply to: antoniovinci
In my 2011 I get this ---
Unknown command "AECCCREATEPOINTS".  Press F1 for help.
:smileyhappy:
Mapimport then select ASCII point file works, however you may need to select the points(blocks) afterwards and change the scale factor in the property palette to 1.
Murph
Supportting the troops daily.
Member
paduroiul
Message 4 of 8 (871 Views)
05-04-2012 12:10 AM in reply to: paduroiul
I don't have the option "mapimport". I just have Map Setup and no option for ASCII import file
Alfred.NESWADBA
Message 5 of 8 (869 Views)
05-04-2012 12:16 AM in reply to: paduroiul
Start command _MAPIMPORT, if that does not work you have either no Map3D2011 or you have an invalid AutoCAD-Profile. Type the command into the command-line press <ENTER> and let's see.
- alfred -
Alfred NESWADBA
Member
paduroiul
Message 6 of 8 (866 Views)
05-04-2012 01:16 AM in reply to: Alfred.NESWADBA
it works, but all the simbols and texts are really large Icouldn't rescale them
Alfred.NESWADBA
Message 7 of 8 (859 Views)
05-04-2012 02:22 AM in reply to: paduroiul
Two options:
  • select one of the blocks, right-click ==> open in blockeditor, scale the content of the blockdefinition, close blockeditor with saving and run command _ATTSYNC one.
  • select all block-insertions, open the property-window (<Ctrl>-<1>) and set the scalefactor X/Y/Z to a value you want to have it.
- alfred -
Alfred NESWADBA
Member
paduroiul
Message 8 of 8 (857 Views)
05-04-2012 02:37 AM in reply to: Alfred.NESWADBA
It's working
Thanks!
Are there any options regarding scales, renumbering, modifying the elevation?
I don't know if you've heard of TopoLT, with this application you can do all of the stuff I've mentioned above.
Do you know any free lisp which does these kind of operations?
