Hi folks,
I've done a search and not found any posts since before 2010 and they didn't solve my problem. I have been sent a very large number of files for which the world file is jpgw not jpw. Is there any way to get AutoDesk to recognise this? I know that I can get it to work by renaming the world file to jpw, but I have hundreds of files so really don't ant to go down that route.
Nomisc
Solved by fieldguy. Go to Solution.
Why can't you use a command window and "ren *.jpgw *.jpw"? In other words, rename them all at once via the command prompt.
No. The "rename" command does not have any support for paths.
I have used a program called filerenamer but can't find the link at the moment. There are several free utilities on the www to do this, like >>here<<.
If you have any programming experience, you could create your own.
