mkeith wrote:
We just got Map 6 because we need data from a city
that is in ArcView format. I assume it is ArcView format as the data is
*.apr, *.e00, arc.dir, arc*.dat, arc*.nit, *.adf, *.tat, *.txt, *.txx format.
I try the Map/Import feature, and seem to only get the linework. How
can I get the rest of the data?
Thanks in advance, mck
"Mark McIntyre" <Well
href="mailto:markmc@ci.grandjct.co.us">markmc@ci.grandjct.co.us> wrote
in message
href="news:3E271969.58AC32A1@ci.grandjct.co.us">news:3E271969.58AC32A1@ci.grandjct.co.us...
you have quite an assortment of files there. An .apr is an ArcView 3.x Project
file which can be a compilation of numerous shapefiles, tables,text files
etc...
The .e00 files are Arc Info coverage files. You are going to need
to determine which items you want to import and then bring them in seperately.
For instance, when you import a shapefile(.shp) the import function displays a
little table showing what shapefiles are available along with a check box
which you can decide to uncheck or not. In the data column you want to click
in it to activate the elipse which allows you access to the attribute
data(.dbf table) where you can select which data you' like to bring in with
your shapefile. Since you're new to Map6 you really need to take your time and
read the on-line help for importing. Sorry I don't have more time to explain
it further.
Hope it helps.
Mark
format.
I try the Map/Import feature, and seem to only get the linework. How can
