AutoCAD Map 3D General Discussion
0 Kudos
Post 1 of 3
Import SDF
267 Views, 2 Replies
06-23-2012 11:08 PM
Hi everybody.
I have some problem with import SDF to dwg. Geometry in SDF is curve with mixed linear and arc segments.
But the result is not my expected result. (see image below) . All arc segments was imported not correctly.
I'm expecting my data is correctly in the sdf files, but some import mechanism  not work properly.
When I make connection through  FDO it's work ok.
Thank you for help.
1,214 Kudos
Post 2 of 3
Re: Import SDF
06-24-2012 04:27 AM in reply to: tint
Without having access to your SDF-file we can't play with your problem.
But if connection of this dataset via FDO works then connect it with FDO into a new file and then export the map as drawing. That will also convert the SDF-objects to AutoCAD-geometry type. Use command _MAPTOACAD or _MAPEXPORTCURRENTMAPTODWG
- alfred -
Alfred NESWADBA
0 Kudos
Post 3 of 3
Re: Import SDF
06-25-2012 10:36 PM in reply to: tint
Hi  Alfred.
Thank you for help. It's work correctly with geometry.
What about set convertion options?
There are only XDATA option available. My business need Object Data convertion.
Sincerely,
Michael
