hi,
how can i import points, as a closed polyline, shape file or dxf or other format, from Fast Survey (Spectra Precision) to Autocad Map 3d.
the points are saved as crd file. and to import them to autocad i import then as ascii (txt) then convert them manualy to closed polyline format.
i need to have this points in autocad, preferable as polyline. to have a direct and short import to Autocad from the Spectra Precision(Fast Survey).
thanks
Andrei
I don't know what format the .crd file is, but if it's just an ascii text file as x,y,z then you can pretty easily make a script file (*.SCR) from it.
The script file would issue the POLYLINE command as it's firs line, then the remaining lines would simply be x,y coords (z is optional)
For instance, the script file would look something like this.
POLYLINE
100,200
100,300
111,222
123,234
Simply type SCRIPT at the command line, then browse and find your script file to run it. You may also be able to drag the script file right into the drawing to run it.
If the data contains a Z value, then you can use the 3DPOLY command instead if you want that data too.
If the data is not X,Y and is instead P,N,E,Z or something, you can use Microsoft Excel (or similar) to move the columns of data around.
If you have someone familiar with programming (like an IT or CAD manager) they can probably write a little Java or Python script to process the info so you don't have to jump through my above mentioned hoops.
