AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Import of shape files
3 REPLIES 3
463 Views, 3 Replies
Dear all,
When I import the shape file I created to map3d I can select and import individual shape files. I can not however, select all. When I do this I get an eror code.
Please help
3 REPLIES 3
Murph_Map
Providing your version of Map3D, and system specs may help get you an answer. Also what steps are you taking to import?  Srceen captures may show us more on what your issue is.
Murph
Supporting the troops daily.
braudpat
in reply to: Murph_Map
Hello
+1 with Murph
- Which Windows exactly (XP, Vista,Seven,Eight) ?   32 or 64 bits ?
- Which AutoCAD MAP exactly ?  2014/2013/2012/2011/2010/etc ?
- Which error code ?  Which message error ?
- Your shape files comes from : unknown / AutoCAD MAP / ESRI ArcView/Map / MapInfo / etc ?
- How long are filenames of your shape files ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
in reply to: braudpat
It transpired that shape files saved on our work server can only be imported one by one. However, if the files are located on the C: drive first and then imported then I can select all of them.
”Boost
