AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Import large polygon from SHP
6 REPLIES 6
MetroVancouverDrafting
730 Views, 6 Replies
Mapimport help clearly states:
. Objects that cross or are enclosed by the rectangular window are imported.
Is there is a way toto query polygons that are way bigger then the queried area?
6 REPLIES 6
if you don't use the option for "Spatial Filter" in the MAPIMPORT dialog, the import is not limited by any (geographical) boundary.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks for replying.
Unfortunately, it will bring in 700,000 parcels instead of one.
I have tryed option "Current Display" while zooming to the area. Weird stuff, sometimes it works but mostly doesn't.
I tried it, not with "current display", but with "window" ... and for a few samples it worked well (internally was handled like AutoCAD selection "crossing").
So polygons were queried when fully or partial inside the window-rectangle.
I did my test with SDF-file, about 200.000 polygons, using Map3D 2014 SP1.
- alfred -
Alfred NESWADBA
In the drawing query by location there is an option "Point". Works as expected. I need something like this for importing polygons from shape files
Did anybody have a solution? I really need it
MV,
You marked two Solutions a year-and-a-half ago. Were they not really solutions? To be honest, I don't understand what your original question was about. Can you elaborate, maybe throw in a screenshot or two? Or post your data or drawing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
”Boost
