AutoCAD Map 3D General Discussion
Valued Contributor
davidm
Message 1 of 7 (423 Views)
Import data from files
423 Views, 6 Replies
01-29-2013 09:57 AM
I want to import a csv file into map3D and set the layers to which the blocks with attributes are inserted on. I've found in the help guide that using
Click Home tab > Data panel > Import From Files > mapimport.
Problem is, when I do this, I do not get the dialog that the help file says I should, like a place to define an insert layer or schema. All I get is the plain dialog that asks for formatting (file format such as autodesk uploadable file), Z unit, Coordinate system, and create block.
I also want to export the attribute data into a survey point file.
antoniovinci
Message 2 of 7 (419 Views)
Re: Import data from files
01-29-2013 10:44 AM in reply to: davidm
It behaves so, because you must declare how your .CSV is formatted, i.e. what's the meaning of the fields.
Please copy and paste here a couple of .CSV lines, thx.
Valued Contributor
davidm
Message 3 of 7 (414 Views)
01-29-2013 12:29 PM in reply to: antoniovinci
This is from the help file
In the table, you can specify properties for each input layer (sometimes called a schema, level, or file).
To import an input layer, select its check box. To change other settings for an input layer, click in the field to change. Click the down arrow to choose from a list of choices, or click for additional choices.
To sort on a specific column, right-click the column heading. Click Sort Ascending or Sort Descending.
see dialog box,jpg attached nothing like this shows up on my dialog box
here is the first few lines of the csv file.(point number, Northing, Easting, elevation, description)
121913436526767471.9744.667curb cut
122113436525767499.7744.605curb
122213436524767521.2744.54curb
122313436525767526.5744.501curb
122413436525767529744.382
St Drain
Valued Contributor
davidm
Message 4 of 7 (405 Views)
01-29-2013 01:24 PM in reply to: davidm
Maybe to simplify things I'll explain what I'm really trying to do.
I have GPS data in a CSV file. I want to import that data into map so that I have a block with attribute info. I also want that block to be on seperate layers based on the description, so all the curb shots are on layer curb, etc... this will allow me to insert my blocks - like catchbasins and manholes - and connect the points between relevant features.like curbs and edge of bit.
I've been able to import the blocks, but not on specific layers. I've also brought the points in via a survey data store which I like because the data is in a table, but I do not like the formatting of the data having to use the style tool, there is no real seperation.
Robert_Fritz
Message 5 of 7 (392 Views)
01-29-2013 11:23 PM in reply to: davidm
not sure if that helps. When you import a SHP file you can put import data on different layers depending on an attribute in the import data set. This option doesn't seem to be available when importing CSV files.
Have a look at the SHP import - the import dialog box has an option called "drawing layer" (or something similar) - clicking on it opens a new dialog box where you can specifiy which data goes where.
If that helps you would need to convert your CSV file into a SHP file (or any other import file format Map can process via mapimport). I suppose there a free tools available for that.
Rob
http://raumpatrouille3d.blogspot.ch/
Valued Contributor
davidm
Message 6 of 7 (365 Views)
01-31-2013 05:24 AM in reply to: Robert_Fritz
I don't know if i can convert a CSV file to a SHP file.
I'm very frustrated, I would think importing GPS points into a GIS program would be much more refined.
Robert_Fritz
Message 7 of 7 (362 Views)
01-31-2013 05:51 AM in reply to: davidm
low frustration level? Get used to the shortcomings of Map as it is mainly a CAD with additional GIS functionality.
But it is quite flexible if you are willing to work around things.
with regards to CSV to Shp: https://www.google.de/search?q=convert+csv+to+shp
good luck
