AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Imperial to Decimal
3 REPLIES 3
Ronaldo54
315 Views, 3 Replies
Imperial to Decimal
I have drawn a model using imperial units, at a scale of 1:1. When I switch the units to decimal, the unit factor remains the same, eg 5" shows as 5mm.
Is there a setting anywhere that would automaticaly show 5" as 127mm, or do I need to scale my model by 25.4
Thank you in advance
3 REPLIES 3
antoniovinci
in reply to: Ronaldo54
If you set DIMALT = 1 you can display both:
Ronaldo54
in reply to: antoniovinci
Thank you antoniovinci, that is helpful, but what i meant was, is there a setting for listing a line as 5" when the units are imperial, and 127mm when the units are changed to metric?
antoniovinci
I'm afraid not, sir...
”Boost
