AutoCAD Map 3D General Discussion
Active Member
0 Kudos
Post 1 of 14
imageframe not working
5119 Views, 13 Replies
03-01-2012 03:05 PM
We use about 16 different ortho photos we use for maps.  I have changed imageframe 0 1 2 and frame 0 1 2 3 in about every possible combination.  The Tiff file will not show borders, but I can still select it and snap to it.  I want the borders off I am using map 2012.  Am I missing another variable?  At one time the borders stayed off and I couldn't accidentally snap to the corners.
Set IMAGEFRAME to 0 to turn the frames off
Set FRAMESELECTION to 0 to turn off the selection, otherwise you can still select the images with the frames turned off.
It should resolve your troubles
1,210 Kudos
Post 2 of 14
Re: imageframe not working
03-02-2012 02:00 AM in reply to: coswald
how did you reference the images? Via FDO or by MAPIINSERT?
Have you tried to run _AUDIT?
Have you installed RasterDesign?
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 3 of 14
03-02-2012 08:01 AM in reply to: coswald
I used Mapiinsert and I have run the audit with no errors.  I have even tried it on several different computers.  It used to work with earlier versions.  Any other ideas?
Distinguished Mentor
35 Kudos
Post 4 of 14
03-02-2012 09:38 AM in reply to: coswald
I just checked the help file for "IMAGEFRAME" and it has a hyperlink to "FRAME" - Under "FRAME" it states that this variable overrides Imageframe, dwfframe......
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
1,210 Kudos
Post 5 of 14
03-03-2012 05:47 AM in reply to: coswald
setting FRAME to 0 doesn't change anything (for me) if I inserted the images via _MAPIINSERT.
But setting IMAGEFRAME to 0 solves it for me ... the frames disappear on the screen.
If you set FRAME to 2, then IMAGEFRAME to 0 (that was the exact order I used the command) what happens to your current or to a new drawing?
At least does it also be print the image-borders? Also if you set IMAGEFRAME to 2 where the frames should be displayed but not plotted?
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 6 of 14
03-05-2012 07:55 AM in reply to: thepworth
I tried that in about every combination I could come up with.  The lines disappear and do not plot, but I still can snap or select the borders.
1,210 Kudos
Post 7 of 14
03-06-2012 12:32 PM in reply to: coswald
what file-format do the images have?
I can't reproduce this problem (TIFF), sorry for the moment.
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 8 of 14
03-06-2012 01:20 PM in reply to: Alfred.NESWADBA
That's ok.  Autodesk called me yesterday and I showed them the problem.  Tried everything, still does not work.  I just want the image to show up and not be able to select or snap to the image border.  We use several ariel photo's each one is about 5 miles x 5 miles and I have to work in areas that are about 50 to 500 ft.  It is just a pain when I am working on the edges of the images and it snaps 5 miles up, down, or anywhere.  The best part is if I do an erase with a crossing and I just happen to select a border and I have to reload the ariel photo's. I do turn the osnaps off except when I am drawing along several polygons or topo lines that I need the osnaps.  The older versions worked with imageframe set to 0 and frame to 0, It would not select or snap to any photo's edges.  When I need to borders I used to just turn it back on (Imageframe 1).
3 Kudos
Post 9 of 14
03-07-2012 06:11 PM in reply to: coswald
Set FRAMESELECTION to 0.
It should resolve your troubles.
3 Kudos
Post 10 of 14
03-07-2012 06:53 PM in reply to: mazikhelela
