From the CAD Overlay help file....
When you export an image, you can select a new file format. Depending on the
file format you select, you can save the correlation information to a
resource file, a world file, or to the image file. When you export most
image types, the Export Options dialog box presents the following options:
- Maintain Drawing Link to Image replaces the current image definition in
your drawing with the new image definition.
- Burn in Rotation saves the current rotation with the image. The resulting
image will appear to be rotated, but will have a rotation value of 0.
- Write Correlation saves the correlation information as either a resource
file or a world file. Normally, these files are saved to the same location
as the image file. However, you can control this path on the Paths tab of
the CAD Overlay options dialog box.
Jim B.
"markthomas" wrote in message
news:f080e96.3@WebX.maYIadrTaRb...
That's not a big problem for me, I normally don't use more than 4 at one
time. One more question and I promise I'll shutup the rest of the day! Can
CAD Overlay save the image that has been re-projected?
Thank you very much Jim.
Mark
