AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
I re-installed ACAD, now my shp files are corrupted?? Please help
4 REPLIES 4
Jfactory
376 Views, 4 Replies
There has been a different ongoing issue I'm having. I came to a point where I thought it was best to uninstall / reinstall.
Now I have the old issue plus new ones.
My shp files say there is an inconsistency in number of objects.  I can't do anything with them!
Another thread said to delete the .idx files in the folder. I did that. No luck.
How can I uncorrupt these files? I am desperate to get them, it's like 4 months of work!
P.S. Windows 7. ACAD Map 3D 2013 w/ sp 2.1.
4 REPLIES 4
Alfred.NESWADBA
in reply to: Jfactory
What command did you use that tells you that? _MAPIMPORT or _MAPCONNECT?
Whatever command you used, try the other one 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Jfactory
in reply to: Alfred.NESWADBA
Thank you for your reply, but neither worked, unfortunately.
I mainly use _mapconnect. I tried _mapimport and it still said it was corrupted or does not have the same number of objects as the .shx file.  Which is strange because i've only and always edited these files using _mapconnect and I always check in the data.
Alfred.NESWADBA
sorry to say, but I have no tool that repairs SHP-data (and have not searched for anyone yet).
So I guess it's time for a restore from previous backups (or use Google to search for SHP-repair software).
Sorry, - alfred -
Alfred NESWADBA
Murph_Map
I have an old exe that repairs shp files on my old pc sitting in the corner. In the mean time here are two that may work
http://freegeographytools.com/2009/fixing-corrupt-shapefiles
I can't say if they work or not so use at your own risk.
Murph
Supporting the troops daily.
”Boost
