Hey
I somehow managed to turn on the 'Metadata Viewer" window, and cannot figure out how to make it go away. I can close the window, but every time I switch drawings it re-appears in its previous location. Does anyone know how to turn it off permanently?
Solved by Alfred.NESWADBA. Go to Solution.
you are sure it's not the Map-Workspace? (because that has an extra switch within the _MAPTOPTIONS-dialog). Anyway it's strange that it comes back when switching from one DWG to the other.
You can try to close the dialog and then save this situation as new workspace.
- alfred -
Saving the workspace seemed to do the trick. Thanks.
For any one else in a similar situation, I've attacehd a photo of the window i am refering to.
