AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
How to set symbols in AutoDesk Map 3D 2012 whenever using oracle 10g as DB
4 REPLIES 4
TATA_JUNE2007
723 Views, 4 Replies
I have created a template file but whenever I open and display data in AutoCAD Map 3D 2012 it does not apply to the opened data from Oracle 10g. Infact, it change every time I open the data from database!
Please help if any body of you using the symbol in AutoDesk Map 3D 2012. Also note that my database is Oracle 10g.
Anand
4 REPLIES 4
Murph_Map
in reply to: TATA_JUNE2007
Once you style the data you need to save that connection as a .layer file then connect to that layer file. Right click on the connnected data layer in the display manager.
Murph
Supporting the troops daily.
TATA_JUNE2007
in reply to: Murph_Map
Thank you very much Murph,
I have save the connection layer as .layer but again when I open the data then its display with different style. Any thing else i need to look into that..
Anand
Murph_Map
Are you connecting to the .layer file or making a new connection to the Oracle DB?
Murph
TATA_JUNE2007
Thanks mate, it all works now.
Anand
”Boost
