AutoCAD Map 3D General Discussion
Active Contributor
TATA_JUNE2007
Message 1 of 5 (430 Views)
How to set symbols in AutoDesk Map 3D 2012 whenever using oracle 10g as DB
430 Views, 4 Replies
08-01-2012 02:11 AM
I have created a template file but whenever I open and display data in AutoCAD Map 3D 2012 it does not apply to the opened data from Oracle 10g. Infact, it change every time I open the data from database!
Please help if any body of you using the symbol in AutoDesk Map 3D 2012. Also note that my database is Oracle 10g.
Anand
TATA_JUNE2007 wrote:
Thank you very much Murph,
I have save the connection layer as .layer but again when I open the data then its display with different style. Any thing else i need to look into that..
Are you connecting to the .layer file or making a new connection to the Oracle DB?
Murph
Message 2 of 5 (410 Views)
Re: How to set symbols in AutoDesk Map 3D 2012 whenever using oracle 10g as DB
08-02-2012 04:05 AM in reply to: TATA_JUNE2007
Once you style the data you need to save that connection as a .layer file then connect to that layer file. Right click on the connnected data layer in the display manager.
Murph
Supportting the troops daily.
Active Contributor
TATA_JUNE2007
Message 3 of 5 (408 Views)
Re: How to set symbols in AutoDesk Map 3D 2012 whenever using oracle 10g as DB.
08-02-2012 05:02 AM in reply to: Murph
Anand
Murph
Message 4 of 5 (387 Views)
08-03-2012 03:29 PM in reply to: TATA_JUNE2007
Murph
Active Contributor
TATA_JUNE2007
Message 5 of 5 (298 Views)
08-27-2012 12:49 AM in reply to: Murph
Thanks mate, it all works now.
Anand
