Any assistance with this query would be grateful. My system upgrade to Windows 7 Pro doesn't seem to support my Map3D 2009. I am a light user of Map 3D but would like to continue to have the option of running Map3D 2009without any new bells and whisltles that were introduced in later upgrades which I never purchased as they were not required. This was an expensive piece of software in 2009 and my local reseller is suggesting I will require full upgrade to 2015 Map3D version bascially rendering old software defunct and cost of upgrade as expensive as the first version. Surely there must be a plugin or bridge that I can use to continue to run the old 2009 version. I am using limited functions on the Autocad other than opening and converting layers and some minor analysis. No design or access to online supoprt services. Any help/clarification appreciated. Thank.
Hello
Win Seven is officially supported by Autodesk with 2011 versions ...
But 2010 versions are running well on Win Seven !
Versions 2009 have some problems on Win Seven ...
A (not free) solution is :
- http://www.longbowsoftware.com/
An other (not free) solution is :
- Create a Win XP Pro (authorized) VMWare PC and then run it with VMPlayer (Free)
Q1) Have you tried to install as Win Seven Local Admin : Click and then "Run as Admin" and launch MAP 2009 "Run as Admin" ?
Q2) Standalone "classic" MAP 2009 OR Network FlexLM MAP 2009 ?
Patrice BRAUD
Pat
Many thanks for your reponse and suggestions. I will certainly try the local admin option and let you know how it goes. In reponse to Q2 - Standalone Classic Map3D if that gives you any further insight. Thanks.
Hello
+1 with Antonio
As far as I know, the Win XP Virtual MSoft PC is very slow and seems to have some strange graphic problems with ACAD ...
But you can test it ... Why not !?
Patrice BRAUD
