AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
How to represent a polygon feature using a 3D building model
3 REPLIES 3
778 Views, 3 Replies
I wish to represent polygon features in a polygon topology using building models created in revit. Can this be done? If so, how?
3 REPLIES 3
antoniovinci
You can't mix the two things, sir.
A polygon topology is a pure 2D Gis concept, while Revit is a stand-alone 3D tool.
Otherwise you could _MAPEXPORT the topology with OD heights, then import it back to extrude automatically the parcels (no matter of Revit stuff).
in reply to: antoniovinci
Thanks for your reply!
So, does it mean that there is no way of creating a realistic 3D GIS model (the best that can be achieved is by extruding building footprints to represent as building structure)
Murph_Map
No.
You can export the RVT file to dwg format and use it in Map3D, you can use Max3D and both a RVT & DWG files.
Then there is this http://usa.autodesk.com/autodesk-infrastructure-design-suite/ .
Murph
Supporting the troops daily.
”Boost
