AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
How to measure area (sq meters) in WGS84?
1 REPLY 1
1507 Views, 1 Reply
We are able to measure distance in meters between 2 points using COGO tools. Though, when meassuring areas (command area) even setting units to meters it shows: "Area = 0.00000073, Perimeter = 0.00343123" which is not expressed in meters. The area in meters is around 8900m2. We are using latitude, longitude LL84 (WGS84). Is there a way to easily measure area over the map using this coordinate system? Thanks in advance.
Tags (3)
1 REPLY 1
antoniovinci
I wonder whether how many people in the world are projecting in Lat/Long: perhaps only you?
Never heard about measuring sqm. in a geographic CRS, so you'd better transform all in UTM, sir...
”Boost
