AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
How to install Infrastructure Administrator for Map 3D?
3 REPLIES 3
ltmullen
442 Views, 3 Replies
I discovered that there is something included with Map 3D called Infrastructure Administrator, and by the description of it I read, it could be useful for me.
However, I can't figure out how to install it. I was told in another thread it should be a part of my installation package already. Can anyone help with this? Thanks!
3 REPLIES 3
david.lau
in reply to: ltmullen
ltmullen
in reply to: david.lau
Not sure whether you noticed David, but that post you put a link to is my own and the issue was never solved...I reposted in this section thinking maybe it would be more relevant here and I'd be more likely to find help.
What version of Map?
For 2012/2013/12014 when you start to install you should have option to check to install Infrastructure Administrator. But because for 2012 is available only for Oracle you need to have install full oracle client, if not you will see there a red mark.
Albert
”Boost
