Greetings everyone,
I am a new member of this forum, however I have been reading the posts for some time.
I am an archaeologist working with survey equipment and Map3D for a few years but now I have the following problem.
When I import the shapefiles created in my leica/topcon equipment into Map3D (mapimport) there is the possibility to select which attributes are going to be imported with an import profile file (.ipf).
How do I create the above and save it so that I do not have to go through the same process again?
Thank you for your help and I hope you can help me
Solved by Alfred.NESWADBA. Go to Solution.
Solved by parkr4st. Go to Solution.
I understand you want to save the .ipf file. correct? If not details.
In the mapimport settings window lower left there are save and load buttons for that purpose.
dave
May be I don't understand all correct, but in the same dialog (MAPIMPORT ==> second tab) you have the choice of saving the settings into a profile (IPF) and left besided of that button you can load these settings from a saved file.
As you have found how to save the settings to IPF I'm just wondering that you have not found the load-button ... or I misunderstood something.
If the question is how to write an IPF-file without using the MAPIMPORT-dialog ==> create one sample file during one start of MAPIMPORT-command and do some settings to get a master-/sample-file, and then open it with an ASCII-editor like notepad, it's just a XML-like file (but I don't know any documenation on that, and to be honest, not searched for that).
- alfred -
Thank you for the quick reply.
I think my eye has been ignoring the save button. The above solutions work for the imported shape files into map3d.
If I want to amend an existng .ipf file can I do it through the same process. There is a load, save button but not an apend button.
In effect I want to add the selected attributes to my existing ipf profile when I import a new shape file and not start from scratch.
Can this be done?
Start the _MAPIMPORT command, then use the load button to get the existing profile loaded. Now you can select additional attributes (or remove some of the ones you used previously) by selecting/unselecting them in the data-column. After you have done that changes ... click onto the save button and create a new IPF for the future.
- alfred -
Excellent and thank you for your help. It was amazing how quickly everyone responded.
