I'm hoping this could be a quick fix without completely re-installing CAD.
I jammed too much LiDAR data into my Index file for point cloud data, and now I can not even open it. Even new drawings are trying to open the overall index with everything in it.
What I want to do is just delete the whole thing and start fresh again, but not sure how to do that. If I could open it once I could start deleting stuff from it, but it is too large to even open.
Any help would be much appreciated!
welcome @forums.autodesk.com !
Open it with ReCap or with Map3D, if Map3D do you mean open the drawing that has the point-cloud referenced or what do you mean exactly (what command) when you write "open it"?
What version of Map3D do you run?
And the most important: what message do you get when you "open it"?
- alfred -
