Show only
Search instead for
how to define features with the Oracle Administration command?
i want to export autocad Map Objects to Oracle Schema, when i click "Select Features..." button, pop up one message, "You must define features with the Oracle Administration command before exporting data." How to do it?
for me it's look like that you haven't yet created feature tables with Map. For the "Oracle Advanced" function which you are using you will have to use "Schema Administration" (command: _maposeadmin) to create these tables. Please have a look at the Map help for further details.
Map 2006 and newer releases offer another method of using data from an Oracle database - "FDO". Please have a look at the documentation for further information.
