style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
"darynb" <Has
href="mailto:daryn.brown@ci.bothell.wa.us">daryn.brown@ci.bothell.wa.us>
wrote in message
href="news:f086ed5.-1@WebX.maYIadrTaRb">news:f086ed5.-1@WebX.maYIadrTaRb...
anyone ever encountered a command or bonus tool which will create mulitple
closed polygons at once? Bpoly will create this one at a time, but will take a
long time to complete. Any ideas would be
appreciated.
this may not be very quick but lets give it a try.
first you need to go to map>tools>drawing cleanup
here you should have 3 buttons, start at the top and work your way down
first button pick select manually and then click on the select button (or it
will do the entire drawing)
click on ok
click on the object conversion button
here I leave modify original objects cheked and check all the option except
circle to arc
click on ok
click on cleanup options (this one can be tricky)
this is all about the geometry of the drawing (all line must be intersecting
other lines)
stick with the default here and hope it works for you. (you might play with the
tolerance a little.
click on ok
click on proceed
at the command line you will see
modified objects
deleted objects
created objects
I will run the drawing cleanup until it reads 0 (usally) on all of them.
ok.... the next step is to go to map>topology>create
here give it a name and a description and click on link objects
(note: there is a centroid box as well, make sure you have nothing on except
the boundaries when doing this. If you have a single peice of text in each
polygon your ok...Map will use it as a centroid otherwise it will create a
centroid for you (as long as create missing centroid is check)). I also have
highlet errors and mark errors check as well.
ok after picking the link objects button click on select manually and click on
the select button
select the objects
click on proceed
if it worked you will see "topology successfully created"
if not it will show you the errors it found
fix the errors and try again
once the topology is created you can create the closed polygons
go to map>topology>create closed polygons
it should default to the name you gave it
select the layer you want the line to be put in and click on ok
good luck
Dave J.
"darynb" <Has
wrote in message
appreciated.
"darynb" <Has
wrote in message
appreciated.
"darynb" <Has
wrote in message
appreciated.
