AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
How to convert rules to AutoCAD layers
1 REPLY 1
toolbox2
349 Views, 1 Reply
I've been given a drawing which needs to be converted to an AutoCad drawing. I can do that but I need the thematic rules (defined in the Style Editor) to be transferred to unique AutoCad layers and the layers named according to the corrsponding Legend Label.
eg. in the Style Editor I have rules such as :
"NAME" = building
"NAME" = tree
"NAME" = road
So, when I run the MAPTOACAD command I want each of the above to be transferred to AutoCad layers named after the correpsonding Legend Label.
Any ideas?
1 REPLY 1
Alfred.NESWADBA
in reply to: toolbox2
one idea is you connect 3 times to the same datasource (so you have 3 different GIS-Layers).
Then you set a fitler, for layer1 filter to NAME = 'building', layer 2 filter to NAME = 'tree' and so on.
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
