AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
How to change the color of a selected map feature
1 REPLY 1
1266 Views, 1 Reply
hello,
I have attached two snips.
snip1 shows an unselected object in map3d, the color of which can be controlled.
snip2 shows a selected object and i wanted to know if this color (i.e. the color that shows when the object is selected) can be controlled or not?
thanks in advance
1 REPLY 1
hence_the_name
I'm not sure - the color for the selected feature depends on the color of the feature itself and probably on the color of the drawing background as well - so it is not fixed but dynamic. Looks more like an algorithm is used to choose the selection color. But I'm only guessing,
Rob
http://raumpatrouille3d.blogspot.ch/
”Boost
