I have created polygon topology named "polygon" and created a table named "My" as object data. I want to see the text 1, 2, 3, 4 in the field of Un_ID of the Polygon. as shown in the dwg file. I have generated link with the text but it is not showing in the property window. Please help.
What have you done to transfer the text-content to the object data?
If you can upload the drawing we can see what objects are used as label, if there are any dependancies between the text object and the topology.
- alfred -
Hello Alfred,
Thanks for your response.
I am going to summarise steps of procedure which I have followed:
1. I have created 4 polygons and created a polygon topology "polygon".
2. I have created four text i.e., 1,2,3,4 in new layer.
3. I have defined object data and created a table "my" and created a field Un_ID with integer type.
4. I have attached object data to the 4 polygons.
5. after that I have generated link and selected enclosed text.
Please let me know if drawing is required for further illustration.
sorry yes, the drawing is required, because I don't understand the step, how you assign the object data to the "polygon" of a polygonal topology.
- alfred -
to make my scepticism more understandable:
You have selected a polyline, but you are speaking from polygonal topology
That might be assumptions (also wrong ones) from your screenshot, and that's why a drawing is needed.
Hope that is not better understandable, - alfred -
