AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
How do you fill in polygons in 3D Space
1 REPLY 1
duanuys
845 Views, 1 Reply
For my job here I have a contoured map of a sand structure. I have converted that entire 2D map into a 3D map. Showing the elevation of the contours relative to the surface. I need to know how you can hatch or fill in with color the 3d polygons that are shaping the subsurface. When i try to hatch it, it works but it just pastes it at the surface at Z:0 and even if i bring that hatch down it won't form to the multidemnsional polygon that i am trying to cover. Can anyone help me? Here is a pic of what I am trying to do.
The geen/blue is the fault plane i have been able to plot as well as shade in using 3D Face, but the problem I run into for the RED contour lines is that they are arcs and when i use 3D Face it doesn't allow it to bend to conform with the arc shape.
1 REPLY 1
antoniovinci
in reply to: duanuys
Try the _LOFT command between the contours.
It won't be good-looking as a true Civil surface, but better than the.. rubbish you posted, sir.
”Boost
